burn smell in new tesla S when heat is on
Hi
Just received my new tesla, and i noticed when turning the heat on, a burned smell appears - I wonder if this is normal and if it will go away after we while?
COE
Probably. Someone else said the same thing about a month ago and never said anything else. Might just be new car stuff. Taht said, if you see smoke then I think it might be a problem.
Normal. Goes away after a few days.
Just like the first time your furnace comes on in the house, the dust in the ductwork gets burned out.
I had the same experience. It did go away within a week, but at first was a bit disconcerting. I did a lot of windows-open/pano-roof open drives the first few days to eliminate the initial smell.
Same issue, went away in a couple weeks.
I used to have baseboard heaters in a house I owned, so not surprised. Fyi, if you have the heat off all summer, you will have the smell back for a bit in the fall, but its normal for electric heat. Burning dust as jat said. Nothing to worry about unless you see flame... ; )
Indoors, about 80% of dust is human skin flakes. You're smelling yourself going up in smoke.
Mmmmm.... pork!
Normal - we had it for a day, and then it dissappeared. It may actually have been a sealant, probably not dust as the car was new - smalled a bit 'electrical'. Anyway, not a long term issue.
sorry 'smelled'
How about that "new car smell?" No one has commented on that. Is it present when you get your car? Can you smell the leather? Again, living vicariously through all of you until I can take delivery!
I've had the car 9 weeks. I can't smell anything anymore, but folks who are seeing the car for the first time still comment on the 'new car smell'.
Yup, very common on any new car, even more so with a new ICE.
I had this same issue for the first couple of weeks that I had the car. It seems to have gone away now.
Day 9 in the car, super strong acrid "burning rubber" smell just showed up on the 4th drive of the day. Have aired it all out, will check again tomorrow. Was any of the smells above "burnt rubber like"? Not in the frunk or trunk, closer to driver and passenger seats.
Are you sure that it's not from the rear tyres? ;)
@mark e. grin
Eyal in this thread says it is the rear parcel shelf outgassing...
http://www.teslamotors.com/forum/forums/something-smells-burning-wire
